Most of my washers had fairly pronounced ridges where the satellite gears wore into the washers.
To the extent I could get the anvil of the micrometer into the part where the gears were running, they all measured from 2.8 - 3.18 mm so according to my theory, I need washers that are about 3.5mm unless I replace all of the planet gears. Unfortunately, the thickest shims I can get locally are 3.15mm. I would order from CTA except they want $75 to ship $30 worth of shims....
My plan at this point is to install the 3.15 washers and take the measurements again so that if I have to order a second set, I can be certain they will be the correct thickness.
