Did you buy some speedie sleeves for the output shafts? You might have troubles finding htem in the US as they are metric!
Thanks. Wishing you a Merry Christmas as well.Just so that you are aware. Have a good Christmas John and I wish all the best for the New Year. Hopefully the vaccine proves effective and your fellow country men can again feel safe!
Probably made from Indinium!I ended up getting new output flanges from Jose Franssen since I was already paying the cost to have a new floor pan shipped to me. Indeed the 36mm speedi sleeves are impossible to find in North America. I would have had to order them from Australia. The new output flanges were about the same cost as the repair service Franssen offers. I just hope they are not made of Chineseium...
Well, I spoke too soon about the new output flanges. It turns out there was a trap for the unwary (which in this case was me). After I fully assembled the transmission and duly applied "hermetical" to the underside of the stepped washer, I decided it would be a good idea to put oil in so I could verify the integrity of the various gaskets. I was disappointed to see a steady drip of oil from around the nut and washer holding the output flange onto the output shafts. I pulled off one of the output flanges to compare it to the original and noticed that the original had a snap ring in a groove, which was not present in the replacement flange. Without the snap ring, the flange was free to float. The nut had bottomed out on the splines themselves. Sure enough when I searched the box from the last shipment, there were two snap rings at the bottom of the box. There were no instructions or anything in the box to indicate that the output flanges were a "kit" that needed assembly.I ended up getting new output flanges from Jose Franssen since I was already paying the cost to have a new floor pan shipped to me. Indeed the 36mm speedi sleeves are impossible to find in North America. I would have had to order them from Australia. The new output flanges were about the same cost as the repair service Franssen offers. I just hope they are not made of Chineseium...
Precisely!I didn't even notice they were there! Do they just limit the depth the flange will sit on the output shaft?
Neither did I until I noticed that the new flanges were floating on the output shafts with the nuts done up tight.....I didn't even notice they were there! Do they just limit the depth the flange will sit on the output shaft?
I hope that you put a sealant under the nuts and the washers on the shaft to prevent oil seeping along the lines and out through the faces flanges of the output and the cardan yoke of the drive shaft. Take it from me --- they leak!Neither did I until I noticed that the new flanges were floating on the output shafts with the nuts done up tight.....
Yes, I did (both times). The manual mentions the necessity of smearing 'hermetical' on the face of the stepped washer. What it doesn't mention is installing the snap ring in the yoke. I imagine the original replacement parts came with the snap ring already installed so it never occurred to the writers of the manual to mention it. Actually, the sealant issue is what let me to take everything apart to inspect. Without the snap ring, the sealant was the only thing resisting the end thrust of the driveshafts and I knew that couldn't possibly be right...I hope that you put a sealant under the nuts and the washers on the shaft to prevent oil seeping along the lines and out through the faces flanges of the output and the cardan yoke of the drive shaft. Take it from me --- they leak!
