I figured I should start my own thread rather than periodically hijacking Shane's transmission thread. As I mentioned in my brief hijack, the nut holding the pinion shaft assembly to the front bearing was so loose I could move it even before I bent down the tabs of the locking washer. It turns out the nut/dog at the end of the primary shaft also was only finger tight once I knocked down the locking washer tabs,
The crown wheel has the appropriate inscriptions on it, so at least I know what the pinion depth should be.
The output flanges have some pretty deep grooves in them and are pitted. Hopefully I can get a speedi sleeve to fit.
The only thing that really concerns me is I cannot move the synchro to lock into either second or third gear. On the SM transmission I built, it took minimal finger strength. I wonder if the synchro is damaged?
