I'm sorry, I thought equal tyre pressures side to side was a given......and the Koleos doesn't actually have a transfer case.......
That's just a right angle drive! This is a transfer case:Koleos magic box. Otherwise known as a transfer case.
Just make sure you use transfer case oil in your right angle drive.That's just a right angle drive! This is a transfer case: View attachment 137499
With the gear in neutral?
There should be no movement transmitted up the chain in a manual 'box, not sure about automatics but I imagine it shouldn't either (otherwise what's the point of neutral?).
Yes, you would be spinning the diff, and yes you would be spinning the secondary shaft in the 'box, but that's it. No gears should move.
Yes, the diff crown/final drive would be spun the "wrong" way around (i.e. the diff crown spins the final drive instead of viceversa), and I guess that is where the problems might happen because I think hypoid gears don't like doing things the wrong way around. I think we found it.
