Hi All, back again, I have managed to source a motor as I could not find a gear. A genuine motor was going o be $1k so I found something that would fit the mounts and it does a pretty good job of that for a lot less$$$. I have finally found time to install it and with a bit of flexing I have the new motor installed. The new wiper motor is a 5 pin and the old motor was a 4 pin. I believe the difference is that the 5 pin has a separate park circuit for low and high speed where a 4 pin has one circuit for the park.
I have figured out the low and high speed on the old motor
black=earth,
green & yellow = high speed +ve
yellow = low speed +ve
red = unknown
and new motor
black = earth
blue = high speed +ve
white = low speed +ve
red = unknown
yellow = unknown
I have tried wiring up with the known match of earth, low and high speed but it doesn't seem to work as expected
Where I'm stuck is that I can't figure out the auto park for the wipers to get them to stop in the lowest position. I suspect once this is in place everything will work as required.
I have also included an image of the top of the new motor showing the red and yellow wires connecting to the top plate of the gear in case that helps.
With the three wires connected (earth, low and high speed) the motor currently engages and does a few swipes, turns off and then waits for 20 is seconds and then does a few more swipes and repeats.
Any ideas on how to progress greatly appreciated.
black=earth,
red = unknown
and new motor
black = earth
red = unknown
yellow = unknown
