Well some success today, charged battery in situ. Attempted multiple starts. Checked fuel pump no fuel pumping to engine bay. Checked the known fuse box connecter pin 11 pink wire problem. Aha only 7 volts pin not mating with any tension. Fixed pin. Attempted start cannot hear in tank pump again pins not mating properly and dirty. Contact cleaner and tensioned the pins. Prime the fuel pump by multiple key turns to Accessories only and one full turn and we have lift off.run for 20 mins to check all the lights door locks windows etc. Passages Window stuck down from drivers control works okay from passanger side?
Okay so let's see if we can drive it.......nope no gears work forward or reverse manual or auto. Okay Ken where is that Lexia hopefully have it dropped off tomorrow.
Any clues guys can this be an electrica,l ECU or physical problem.?
