just found this article, looks like Addo knows I need a new pump and filter and box out
c8 automatic gearbox (al4) issues - Page 2 - French Car Forum
Hi Dimi
That's disappointing.
Looking at picture 5 i see it says EVM deactivated. Does anyone know what that means. Is the 'electro valve main' turned off by the ECU ?? Why ? I must say the Lexia side is not my best side You said you activated it, can you do so with it running.
Jaahn
Oh it won't be that simple smiffy ...
Also tracked down a replacement Comm2000 which should sort the remaining electrical ECU issues after my dumb mistake with the jump start connection reversal (see other post). ��
I can see how that would be easily done on a C5. I almost made that mistake myself yesterday. Who ever heard of marking the POSITIVE with black, and the NEGATIVE terminals with green?
Black , in Australian cars at least, normally means Negative.
I put some RED insulation tape on my Positive wire so I won't do that again.
Cheers..
Quick update, all assembled and everything torqued on, just the gear change cable to be adjusted and check all hoses and cables are connected, not leaking and should be up and running tomorrow. I also ordered a replacement rear gaiter for the rear hydraulic actuator from fleabay so I have a couple of weeks to work out if I will attempt that task .�� anyone replaced one before?
Look at this on eBay Genuine Rear Suspension Cylinder Rubber Boot For Citroen C5 MK1 & MK2 527264 | eBay
Sent from my GT-I9195T using aussiefrogs mobile app
