"Now the dilemma, how do I get the holes to 19mm? I do have a 19mm drill but that won't fit in the milling machine. I have to drill it by hand with an electric drill but it is going to grab like hell. I can make it 18.5mm as well and then ream the holes to 19mm but still, the drill will grab. Does anybody have a trade secret of how to do this?"
Frans,
Great work ! You asked about how to prevent the bigger drill grabbing. I feel you would know this already but to prevent that grabbing, drilling brass you reduce the rake of the cutting edge by grinding it flat on the grinder. So the edge is 90deg and does not pull into the metal. You just need a small flat on the edge. So the cutting edge is still sharp but the angle in reduced.
It is similar to step drills that have no rake as the cutting edge is formed by the milled 'slot' down the length of it. I have used a large step drill to drill out the center holes in some mags to 60mm so they would fit a Reno 4 stud. Like you I was just trying to enlarge the original hole some mm larger. Worked Ok but I did use a larger pillar drill as a hand drill was too hard to handle at 60mm.
Good luck Jaahn
Frans,
Good luck Jaahn
