They do look like those shims!
I never removed the cam extension ..... weirdUsually when we pull a box off, we take the pulley off, but don't remove the cam extension, so we would never see these shims. They just sit there against the bearing, out of sight.
It's only if we pull the cam extension off that we find them.
that's probably it ... can the shaft be removed from the front ... or do I need to pull it back out and split the box/motor back apart ...You might have tipped the box on its nose, and not noticed them falling out.
Oh, they fit through the bearing retainer. Ok, now it makes sense. I had no idea how/where they had come from given that diagram showed them buried inside the extension.No, look at the parts drawing I posted.
The washers go in from the front, before you put the pulley on.
They should slide in through the bearing retainer, which is screwed into the housing.
Sparesbox is pretty good. This is their EBay listing for Bendix Dot 4, 4L for $38 with free post.Does anyone know where to buy 5litres bottles of brake fluid these days? .... or know of cheap brake fluid on clearance anywhere .... Its not the cheapest of stuff to buy in bulk!
cheapest brake fluid I have ever seen. I've grabbed a couple of bottles. I probably should get another and flush it..... I'll flush the tank with metho before I fill it. Given the snail paced progress ...... we are talking weeks and weeks awaySparesbox is pretty good. This is their EBay listing for Bendix Dot 4, 4L for $38 with free post.
If you jump on their website most of their items are free post on there as well.
I've bought a fair bit of stuff off them, cheap as, and quick delivery.
PS, I see you found the EBay listing I was going to attach.
They are based in Vic so you'll get it pretty quick.cheapest brake fluid I have ever seen. I've grabbed a couple of bottles. I probably should get another and flush it..... I'll flush the tank with metho before I fill it. Given the snail paced progress ...... we are talking weeks and weeks away
Have you tried Greg Feinburg?
Ken
