The Adblue product and its suitability in Peugeots
WAOFFROG
Mundaring, W.A. Aust.
After about 190K Klm and 17 years of age the indication "Additive Level Low" and then the question; to add Adblue or Peugeot's recommended product.
Due to location, a national auto service company used Adblue for their stock, but after some 10 months things began to go amiss. The situation has been reversed through a Peugeot concessionaire and all now seems to be in order.
I welcome input from any of the Forum on this matter.
Adblue is perfect in Peugeot vehicles that are designed for it.
Always use stuff that meets the specs recommended for your car.
A car from that era won't be using a urea based product. Eolys or equivalent brand for HDI filters is cerium based, hence the cost. Much less is used.
I would say Adblue is not suitable for a 17 yr old Pug.
It’s designed as an SCR fluid (ie. to reduce NOx) whereas the stuff you should be using is designed to burn off soot in the particle filter (DPF or FAP) by lowering the exhaust temp needed to do so.
Of course it’s possible that at that age your DPF is close to needing replacement anyway.
Adblue is usually a post-combustion injected fluid that reacts with exhaust gasses to reduce NOx emissions, whereas the Eolys fluid is mixed with fuel before combustion and used to burn off soot in the DPF to clean it out or “regenerate” it.
The current range of Pug/Cit diesels use both methods (and both fluids) to meet the latest euro emissions, but a 17 yr old Pug does not.
Hope this helps :)
Thank's for that FF. My vehicle is a 2005 407 HDI and I was in a major city in region Vic. on hols. I took the car to a major auto service company for a service and to 'deal with the additive matter'. What I should have done was to go to Aussiefrogs first.
My real issue is that in looking at the web site of the company concerned there is quite a bit about their training and quality procedures. This, to me, would suggest that they ought be able to assess the make, model, year of the vehicles they are presented with and, either, decline the task/s, or be able to carry out what is required by the manufacturer.
Your's is the first of three replies, all of which indicate, to me at least, that there is a lack of critical knowledge in this matter of Adblue, verses what Peugeot requires for my vehicle, despite tell me they "are familiar with Peugeots" and there were plenty of them in that city.
Thank's again for your input.
Thanks for that Seasink. My vehicle is a 2005 407 HDI and I was in a major city in region Vic. on hols. I took the car to a major auto service company for a service and to 'deal with the additive matter'. What I should have done was to go to Aussiefrogs first.
Yours is one of three replies, all of which indicate, to me at least, that there is a lack of critical knowledge in this matter of Adblue, verses what Peugeot requires for my vehicle, despite telling me they "are familiar with Peugeots" and there were plenty of them in that city.
Thanks again for your input.
Thanks for that SLC206. My vehicle is a 2005 407 HDI and I was in a major city in region Vic. on hols. I took the car to a major auto service company for a service and to 'deal with the additive matter'. What I should have done was to go to Aussiefrogs first.
Yours is the first of three replies, all of which indicate, to me at least, that there is a lack of critical knowledge in this matter of Adblue, verses what Peugeot requires for my vehicle, despite tell me they "are familiar with Peugeots" and there were plenty of them in that city.
The HDI engine used in a small number of late cars uses Adblue, as part of the latest EU compliance. It's more common in heavy lorries.
Your engine uses Eolys, kept in a small tank in front of the left rear wheel. A tiny amount is injected into the fuel tank under computer control after every fill.
...snip...
...snip.....
Hope this helps :)
At 190K km's the DPF would be just over half worn - they're usually good for over 300K km's.
Peugeot have now used at least 4 different additives for their diesels.
Eolys 176
Infineum
Eolys Powerflex
and now AdBlue - but only in the very latest models.
Certainly the additive used in our 2009 2.0 HDi is not compatible with the additive used in our 2010 2.0 HDi.
You need to ensure you have the correct additive - not just 'an additive'. The additives are not all compatible.
It is likely that topping up with the incorrect additive will require replacement of the additive tank, and possibly also replacement of the additive pump.
Justin
I've also been trying to get a handle on diesel additives. As my car is the 2.2HDi (C5 2005) we are in the same territory.
One non-French guy suggested his Audi did well with an additive from SuperCheap, but the label clearly states "not suitable for Citroen/Peugeot engines." So the info above is relevant.
Most of the professional feedback I have had is "not" to use any additives, suggesting that the on-board injection metered device is all that you should rely on, plus using better quality fuel. I have had the Eolys Powerflex recommended too, but I think this is purely for the on-board reservoir tank, not as a fuel additive.
I'd be pleased for any other input.
Hi Gary,
With PSA vehicles, the onboard additive tank injects the additive into your fuel tank. You don't put the additive into your fuel tank, but rather your car carries around a reservoir tank of the additive and injects it into the fuel tank when you fillup with fuel.
So yes, strictly speaking you're adding an additive - it's just that you only add it every 150K - 200K km's via the separate additive tank and not into the fuel tank directly.
PSA vehicles (not sure about the AdBlue changes recently) don't require you to pour anything in through the fuel filler other than fuel. It's all relatively maintenance free other than the additive tank topups every 150K - 200K km's.
All diesel fuel in Australia (is supposed to) meets the same standards.
Justin
You have to consider what the additive is for. The injected Eolys/Infineum is to enable the particle filter to regenerate. Most fuel additives are abut selling hope rather than anything measurable. There is an exception - water in diesel in the tank can grow microbial life, and if you find this clogging your fuel filter a biocide may be in order.
In a C5, the factory Eolys fill is typically good for about 180K, but varies with driving conditions.
Eolys is NOT Adblue. They are complementary processes.
Anything badged as BlueHDI has the Adblue urea SCR system.
See also re Eolys variations and refilling:
Lexia and EOLYS?
Correct EOLYS for my C5?
Just in case anyone is wondering, if adblue gets into your fuel, it will DESTROY the H/P pump and injectors.
Not a cheap repair. I don't recommend trying it.
Hi Gary,
Justin
Thanks Justin, that is my conclusion too as well from the various inputs.
Going a bit further with C5 HDI (etc).
a) I assume a warning dialogue will come up when the tank is exhausted? (And that would be Eolys Powerflex I assume?)
b) I gather that a "good run" (say 1/2hr at 100KPH) is recommended as the right way to clean the system?
(But is there an alternative?... a friend with a C5 is unlikely to do this!)
c) My car is going for a Lexia check tomorrow, but has had the following alerts:
- Engine management fault (intermittent) ... sometimes loses power when this happens (but not strictly limp mode)
- anti pollution fault
d) is the particle filter cleanable (manually)?
The car has done 260K and only has a limited service history record.
Does anyone have a "view" on putting in the blanking plate on the EGR? I gather this may be controversial ;-)
Just to clarify, eolys is still used in ALL current PSA diesels?.
Yes it is.
Simon - can you quote where you get that information from ?
My understanding is that current models use AdBlue.
' The SCR system will be progressively fitted to HDi diesel engines during 2014*. It uses a fluid called AdBlue®.'
AdBlue®
Justin
Gary,
a} - Yes - a dash alert is issued when the tank needs refilling. Powerflex is used in the 2010 range cars. Eolys 176 / Infineum in the earlier cars.
b} Yes - you need a 'good run' on a regular basis ideally
c} Yes - check and see what codes turn up
d} Yes - you can request a manual 'regen' of the DPF via Peugeot Planet with the Lexia plugged in. Ideally you would do this just prior to getting onto a freeway with a nice clean run.
At 260K km's it should already have had a refill of the DPF additive. It would be pretty lucky / amazing to get that far on the original tank / bladder of additive.
With the Lexia cable plugged in with Peugeot Planet running after a regen, you will get an estimated remaining life figure from the DPF, as well as an estimation of what percentage flow remains in the DPF - ie: how blocked the DPF is.
Justin
