After about 190K Klm and 17 years of age the indication "Additive Level Low" and then the question; to add Adblue or Peugeot's recommended product.
Due to location, a national auto service company used Adblue for their stock, but after some 10 months things began to go amiss. The situation has been reversed through a Peugeot concessionaire and all now seems to be in order.
I welcome input from any of the Forum on this matter.
The owner's manual in these cars confirms this, with a page or two on AdBlue and SCR and a page or two on the DPF regeneration and additive.Simon - can you quote where you get that information from ?
My understanding is that current models use AdBlue.
Justin
In particular the statement containing "additive particle filter" should hopefully clear things upHow does it work?
Blue HDi diesel technology is composed of:
- An additive particulate filter that eliminates 99.9% of particulates by number, regardless of their size and the driving conditions.
- A post-treatment system called selective catalytic reduction (SCR), positioned upstream of the additive particulate filter and which eliminates up to 90% of the nitrogen oxide emitted by the engine.
Perhaps. The additive tank itself is supposed to last 180k before needing to be replaced/refilled (depending on type). Even this, though, depends on your fuel tank refilling habits.Do PSA DPFs give a longer service life than, say VW, because of it?.
on the basis that there are no stupid questions and in the hope not entirely off-topic -
Why is ash content of engine oil - Quartz Ineo, etc., so critical, given it is hardly a consumable?
ServiceBox also has both systems covered as well.
Here is a page on the new system:
https://www.groupe-psa.com/en/newsroom/automotive-innovation/blue-hdi-diesel-engine/
Both AdBlue and eolys are used in all BlueHDi diesels.Just wanted to clear that up.
Justin
... Tap water or urine as DIY substitutes will probably poison the catalyst!
yes.I've heard some surprising comments from friends on how much adblue needs to be used on a regular basis, which sounds a serious added cost.
Does the quantity needed vary considerably from model to model?
It's a small but persistent cost. Maybe, work on a rule of thumb of 1 litre per 1,000km. It should go a bit further, but that would vary with the type of use. In something like a BlueHDi Picasso, top up every 10K and you won't run out! Supercheap sell Gulf Western 20L for $53 and Penrite 10L for $57, so the cost varies with the source. Cheaper from a nozzle where available.
