This might give you a better idea of how it works. Pressure from the front brakes forces the piston back against its spring allowing the main slide valve to connect the clutch slave to the high pressure supply to disengage it. The spring needs to return the piston to its resting position against the end of the bore to put the governor back in change of the clutch. You can bench test it otherwise you'll need to perform an emergency stop to confirm its operation. I've only had to do it once in 4th gear and was a little surprised to find the engine still happily purring away as though nothing had happened.
- Michael
- Michael
