I'm finally about to reassemble the axles to my gearbox on the R8 G replica. This is a twin shock rear end and 16TS Big box with Steve Swan big uni's/. There is a seal which sits against the shoulder of the needle bearing housing/trunnion . My originals are so badly damaged that I have no idea what they should look like.
Are they a common seal that can be obtained locally or an import job.Mine appear to be a flat rubber seal which would be easy enough to make with a wad punch. Any suggestions or leads would be appreciated. Cheers Brian
