I have been lucky enough to acquire this R10 as a Give Away to Good Home unit, from Canberra, which is of course a story in itself. Suffice to say that it wasn't an easy move to Boonah, but work is now finally under way to get the little beasty back on the road. Unfortunately I don't have the skills or funds to make it a top class project, but when finished it will look nice and drive even better.
It is an R1190 that had been whacked up the Khyber many moons ago and put aside for future work. Strong little cars that they are, the rear end is distinctly concave but the damage did not extend to the radiator, so it does run. What I didn't know is that a former custodian change the motor to an 810-05 version, which I believe was fitted to 12s and 15s in Oz. I am hoping that the 10S head and Weber I have managed to obtain will fit, so 1.3 litres plus the 10S head and Weber should make the little beasty get along "quite well".
The exterior has had some 'work', there are signs of some kind of light scraped-on coating for paint renewal (?). As expected, the interior is horrible and will need to be redone. Which brings me to the point - the two big expenses for someone like me is always going to be body repairs and upholstery - I can do just about everything else. I have had a quote for around $1.5k to replace the rear panel, my BFF (thanks again Rob) has gifted me a used rear panel from his collection. That will be done when the suspension had been completed along with the reconditioned brakes, mainly because the car has to have brakes to be able to be moved into the panel shop.
I will try to keep the typing to a minimum and the posts regular.
BP
BP
