Yeah I just bent it on the press to follow the contour of the cast ribs on the sump spacer. I then tapped the four studs onto the small lugs on the ribs. That photo is only a mock-up: I did press some flats so that the nuts seated properly. I figured the factory one was held in by four studs so that'll do. It was actually quite rigid by the time I finished. A bit agricultural but will definitely do the job. I used super stud loctite and nylocs so I doubt anything will come loose. I had to cut a bit off to clear the oil pump, but I reckon it'll work.
