I have a feeling people are sweating the small stuff and forgetting the big stuff.
The car has run well or at least okay (by the info from Sven). So everything should be fine with the carby and ignition. Or good enough.
Then something happens with a valve and car isn't running well. Car also overheats.
This would not suggest the carby and/or some ignition component(s) are at fault. They may be, but this sequence of facts does not immediately point to that.
If you want to make sure everything is the way it should be with as little unknowns as possible, you can even run the car without a condenser and without the carby. Just spray some start you bastard in the intake and keep the throttle partly open (carby should be there but just for decor for the test).
But the car will not run if the ignition timing is out (I take it the dizzy has been messed with so needs checked) or if the valve timing is not right and I have a feeling this has not been checked properly. Until we know these things are as they should, everything else is paliative care.
I also suspect a head gasket leak would explain the overheating but that's something to look at down the road. The car should start and run at idle okay even with a head gasket leak. It won't run for long and will run poorly and getting worse as temperature rises until it will stop, which is something not unlike what Sven has reported hence my suspicion.
And it matters not that the engine has been standing for long. It has just been rebuilt. I have assembled engines and prepared them for start and left them sometimes for months and they started first thing after that. Like you said, if everything is spot on, doesn't matter how long it sits should start on the first compression stroke.
