Pardon my French (but you know what to do) but this French forum has a member with a problem like yours with a P208, and a replay like dmccurtayne's.
208 : Problème : Pression huile moteur insuffisante. - Peugeot - Mécanique / Électronique - Forum Technique
Type de problème / symptômes Bonjour, Je dispose dune 208 achetée neuve en 2014 / 51.000 km / Essence 1.2L VTI. Actuellement jai le message p...forum-auto.caradisiac.com
Also this
La crépine de la pompe à huile peut aussi se retrouver bouchée par les débris de courroie, nécessitant un nettoyage ou un remplacement.www.largus.fr
Hi seasink.Peugeot has French rappels at https://www.peugeot.fr/tools/campagnes-de-rappel.html
Hi David.I'd think almost all engines here will have had the plugs changed in service by now to a revised plug less likely to crack the ceramic.
Hi.
When driving the vehicle over the past few weeks an alert has displayed twice on the display behind the steering wheel saying from memory, "Engine or Vehicle fault - go to service centre" Interestingly the Navigation then displays the local service centres on the map to make it easier for you to navigate there.
The alert has diplayed twice over a period of 1,100km driving both highway and urban. When I continue to drive I have not noticed anything changed or not functioning or diminished power etc on the vehicle.
I don't have an OBDII reader, so in a moment of inspiration I dropped into Supercheap and paid $30 to have the codes read. I have attached the report here. After the initial read I asked for the codes to be deleted, and they waited while I did a lap around the block, and they the read the codes a second time. On this second read there were no codes present.
The report lists 44 fault codes under seven discret vehicle systems. Many of these relate to non cummunication over CAN bus / absence of a datastream issues, and, also supply voltage faults or outside of range.
44 fault codes does seem a lot and my suspicion is that there is a battery voltage issue, that may be causing these codes and also the in-dash alert. Is anyone able to provide some insight or possible cause to the many codes?
Note: the battery is original and has not been replaced. Vehicle was manufactured in May 2017, but Compliance plated in May 2018, (seems odd), so I am assuming that the battery is 5 1/2 years old. This vehicle also has the battery charge status ECU that controls the charging of the battery and the vehicle has a stop/start feature.
Thanks in advance for any assistance.
Hi BarryCif you haven’t had the timing belt replaced yet, this sounds suspiciously like it. Mine had it also (it’s also 2017 and had done about 75K. The belt starts to disintegrate after a time, and the particles clog the filte, reducing oil pressure at times. It is a service centre task, not a home repair. The sight will, I expect, keep turning up until the belt is replaced, and the internal filter and engine flushed. That’s what they did with mine. Your belt has lasted (if that’s the word) 6 years, which is the expected replacement time. If you’ve had it serviced by Peugeot at correct time intervals, they may come at a no-cost to you replacement. Didn’t for me - my own fault, though. In mid 2017 the third version of the drive belt turned up, from memory, which was meant to solve this particular and serious problem. See a dealership as soon as possible.
No you are not interested in going to the dealer you ignore advice and go into a spiral of ifs and or buts.Hi BarryC
Dealer is not much interested, looking at my options now.
I'm not convinced that using Penrite over Total oil would have made any difference to the deteriation of the camshaft timing belt. The newer belt specification will hopefully resolve the fault into the future.
Cheers.
Hi dmccurtayne.No you are not interested in going to the dealer you ignore advice and go into a spiral of ifs and or buts.
Why ask a question.
If it’s been serviced on time with the correct parts and an engine fails within about 8 to 10 years they must by law help you but if you are unwilling or won’t take the vehicle to them it’s on you.
This Aussie frogs is becoming a joke.
