HI:
I am at crucial stage of installing the Distributor gear and meshing it properly with the cam/pistons.
I want to be sure that #1 piston is in the TDC as its not tough to find as the head is off.
Its knowing its at a firing.
I have included two versions of the install and I am not sure of the terminology.
"The cams at #4 cylinder in balance and #1 cams with their circular profiles uppermost"
If I have the cam and crank gears lined up according to the etch marks on each(cam chain install), that seems to give me TDC but is it firing?
Because its a 807 there is that 53 degree setting that also needs to be addressed.
I have included two pics to show the present piston 1 and piston 4 cam relationships.
