You make me blush, Chris. There are others here who know this stuff, I just happen to be the loudest mouth.
BTW, you may have a loud mouth but at least you're using it, so thank you again.
Matthew
had to use the horns tonight on my xm when some dill tried to do a u-turn with out looking,
i don"t think that driver will ever not check the mirrors or turn their head fore i have the two stage air horns from my old cx
installed, instant stop from the idiot,reaction was like a semi was bearing down and they were history.
AKA the Mrs UFO method - of the past.
This forum gave me another TASK and bought this one:
12V 110nu llC ARTru ckAu toAntiq ueVinta geO LDSty leC OWHo rnLo udAhoo ga OO GA | eBay
I ordered relay but I am thinking I can run directly from battery with push button switch.
What do you think?
Yah, I think you can do that. That's probably about a 5-7A momentary load, so your switch requirements aren't very high at all. Personal preference would be use the switch on the ground side of the motor. However you hook it up, use a fuse. 10A should cover it.
Ok.. compressor checks out. I've got the long trumpet blaarrping away happily after a little adjustment but can't get a rise out of the short one. Actually David, the end piece you very kindly sent is the one working at the moment. The cracked one I have sounds like a loud rasberry and the other one a high pitched asthmatic whistle. Actually I can get a good note out of the working trumpet with just my lungs.
Do I assume they are both f)$&)&?
Matthew![]()
