You get it hot, drain it and go away and have lunch. Come back, put 3.5 litres in (after refitting the plug!), drive it once around a regular sized city block without traffic holdups, going through all gears, then do the overflow test with the remaining 500ml if needed. I don't think the oil is the root of the OP's problem. More likely the multifunction switch or a bad pin in a socket.
The marking of the case re the electrovalves / solenoids related to the change from the original type with the white plastic connectors to the type with the black connector. In production, that change was made very early on, say about 2001/2, so no C4 would have had the early type electrovalves. You wouldn't expect to see any markings on the case to indicate that the car had had an electrovalve change.
