Overfinch,
Where do we start?
I understand that the "123" ignition system has more features than the "Power Spark". The latter would be the best for you, financial position etc.
The "PowerSpark" unit cost me about A$70. Sent from the UK
I notice your system has a ballast resistor attached to the coil. You would need to replace this with a more common 12 volt coil. Peugeot specifies the ballast resisted coil for tropical countries.
I've never seen one on a Peugeot sold in Australia ?
If considering a "Power Spark" unit you will need to specify the brand of the distributor ie Bosch or Ducellier. They are simple to fit some care needs to be taken with the coil connections.
I don't want to seem critical but you really need to give the engine etc a thorough clean up. I say this because you mentioned starting difficulties. Any moisture [wet weather] will cling to dirt/dust causing ignition leakage and poor starts.
"Alanquin" is the French brand of shock absorbers. As noted previously I may have the spelling wrong.:disappr: Have you tried other makers? I understand "Gabriel" are known in Africa.
Back in the day we would identify badly worn front wheel bearings by road testing, by moving the car from one side of the road to the other if any noise showed up it was a good chance the bearings were on the way out.
The other way was to raise the car, jack or hoist, spin the front wheel/s and listen for noise. You will need to make sure the brakes aren't dragging.
The only other/proper way is to remove the wheel hubs take out the bearings, clean thoroughly [kero or diesel] then inspect looking for chipped rollers or balls and their races. If replacing clean out the hubs then repack including the bearings with suitable grease.
Don't overtighten the hub nut/s.
By 'riding the brakes' I meant while driving just lightly apply the brakes to hear if there is a change or not of the noises you've mentioned.
The radiator shroud, yes if you can locate one. I have run my 504 without for a short time. Never noticed any dramatic changes. My system has a reconditioned radiator, correct thermostat and correct 4 lb/ radiator cap. [check yours]. The previous owner/s have locked up[welded] the magnetic fan I've yet to address this.
You certainly have had a "swag" of issues with the 504. Not unusual even in Aus. The good thing with most early Peugeots is that you can see a "light at the end of the tunnel".:wink2:
Keep up the photos etc.
Yours
Wildebeest
Hi Wildebeest
Would you be referring to this?
Sent from my Infinix-X600-LTE using aussiefrogs mobile app
