A couple of comments that may be useful : The earliest 16V Hdi's (early facelift C5, and 406 cpe UK, at least) had a pump in the tank and the engines had a belt driven fuel pump, not on the end of the camshaft as they later all did. These engines have an alloy inlet manifold, not black plastic.
And the simple way to settle the question re lift pump or not, is to look at the top of the tank : 4 wires implies fuel pump, 2 wires means gauge only. Or as a Peugeot mechanic said " if it has a primer up front, no pump down back".
Having had C5's for a while, there's a few "unfortunate events" I recall. At times when the 16V RERHRJ wouldn't start, cranking while working the squishy priming pump thingy always worked. Having the tank full helped, but trying to convince impoverished offspring of this was another matter.
The series 1 Hdi has only ever needed an Airflow Meter. China $26, made a huge difference.
