9
Pink #11 [in the grey MTP] is pink (for choosing a colour - it is similar to the black pin #16 that I believed was the same pink cable at the pump).
Checking out this pin's actual terminals they are not silver but we'll and truelly tarnished albeit ever so lightly.
Still busy with non Citroen issues tomorrow but will confirm that this Grey MTP pin # 11 is the same cable at the pump.
Upon doing so, I'll certainly adapt a relay to get those 12Vs to the tank pump for once and for all.
By the by, the heat stressed pins in the green MTP belonging to the AC control module explains those failed Valeo controlers with those pissy little terminals being supplied with far too many amps no doubt
Best regards
John
Once again you have excelled. I've not had much time but did check out those MTPs and in particular the grey one.Sorry, I've misled you. I confused the sockets in the diagram and you want to look at the grey socket. GR=Gris=grey. VE=Vert=green.
The pin allocation for the grey socket has the pump fed from pin 11. Pin 12 is empty I expect for the HDi. I think pin 10 will have a wire connected already.
Grey socket:
Green socket. Melted pin 16 is listed as being for AC.
Black socket:
This is a portion of a relevant wiring diagram and you will see pins 8 and 16 on the green socket are joined and supply the cabin AC blower. It was common for the wiring to have a meltdown at the fan module end, but you have this issue at the BSM end. While it already has a relay in the BSM for this, since the pins are already damaged you may need to add another high current relay (F18 is a 40A fuse) into the line feeding the blower to reduce the current being drawn through pins 8 and 16.
Best regards
John
