Hi Guys, thanks so much for all the input, its great to have.. i can almost imagine we are hanging around in my shed with Beverage of choice commiserating with me!.. i feel encouraged, however, even without beer and company, so here is the update..
Tonight, i have gotten as far as i think i want and need to go, have removed remainder of camshaft covers, including fuel and vacuum pumps, EGR tube, timing chain tensioner, chain, camshafts, and rockers, such as they are..
The score is 8 all; for the rockers, ie 8 still good, and 8 in various stages of fracture, 2 completely severed.
The inlet camshaft is solid, so no chance of rotated lobes here, i am however left feeling hollow by the exhaust camshaft, which is well ..hollow and of composite construction..
I appear to have 4 sets of lobes facing the 4 quarters of the compass, which seems reasonable to me, but how can i check this accurately enough to know whether or not i need to buy a new camshaft?.. and what do you all think of the wear on these lobes?
I used a straight edge and a caliper to compare the valve height with each other, and each of the inlet and exhaust sets of valves showed identical height, which i am going to take as news that i do not have any bent and stuck valves. the rockers appear to have all torn/fractured cleanly, i am confident i have all pieces safely removed..
so, thanks again froggers, feeling better about getting this girl back on the road with the bits she was born with, i was not worried about the Electrical ecu side of things, the present ecu's will be just fine, i would have been keeping all electrical sensors, plugs, looms and injectors from the current engine, afaik this means the car would be completely unaware that anything had happened between battery disconnection and reconnection..
So it looks like i might be able to get away with:
Timing belt kit (incl WP)
Timing chain and tensioner (maybe?)
inlet manifold gasket set
Correct rtv for camshaft cover seal
set of rockers (all 16)
lifters (while i'm there)
Front crank seal
fluids and filters
many, many layers of skin off my knuckles
what am i missing?
Cheers Ben
Front crank seal
fluids and filters
what am i missing?
Cheers Ben
