Hi All,
I am long time french car tragic, and i find myself in dire need of some advice, have searched the forums and the internet at large, but haven't found the resources needed.. so throwing myself at your mercy!.
I have purchased a "Bargain" 2007 C4 Grand Picasso, as a "non runner", that broke down at highway speeds. The car has the 2.0 HDi RHR engine and proper auto gearbox, and 270,000 odd km. the vehicle will crank but not start.
The PO stated that the check engine light came on, and the engine lost all power, and was not able to be restarted. it was not overheating or performing strangely before this failure. It was then towed by RACV to the exact spot i rescued it from, the car was sold to recoup the cost of tyres on their replacement vehicle.
This sounded like a timing belt failure to me, engine codes included Camshaft position sync error, (which i had seen before when my C5 2.2 hdi skipped 2 teeth..)
Skip forward past the 860km round trip and servo trailer tow home (legendary C5 pulling power), and initial disassembly, to finding a very worn timing belt missing 14 teeth!. I had the crankshaft pinned with the correct pins in place, but am not able to position the camshaft to pin it in place, i get around 1/3 rotation only before the bolt on the camshaft begins to move (either direction), and i don't want to break anything else...
I have removed injectors, valve cover gasket, but man!, even lying across the engine, i cant even see into the top of the engine to see what damage lies in wait for me!?. what were they thinking!.. from my pre-purchase research, i was expecting at best case to be replacing rockers and a new timing belt kit, and that's about it?, but i don't feel confident i can find all of the broken pieces with this little visibility?... also, would broken rockers seize up the camshaft(s), or does it sound like there is more or different damage? the car cranked over fine before disassembly (although a little "Gallopy"),
My aching back and i are thinking it might be best to pull the engine/gearbox from the car to continue?, as my predicted worst case was to buy a used low km engine, and still be well ahead of the next cheapest Picasso.
I would love to hear your thoughts about what i should do/check next, i have a lexia that's working fine (was able to reconnect and calibrate the handbrake cables the RACV helped with ) and little invested just yet.. I have a couple of quick specific questions:
a. can someone share a link for the process of removing the diesel engine from the C4 Grand Picasso (2007) (i have a C4 Haynes manual but it doesn't include GP)
b. Can i use any RHR engine to replace mine in the C4GP?, ie 307, 407, C5, C4... i have a lead on a low KM and low $$ engine from a 407 with 6 speed auto.. hoping to go in this direction!
Thanks so much guys, really appreciate any advice or tips, i love these fantastic quirky cars..
Regards
Ben (SA)
Regards
Ben (SA)
