Vehicle pulls left especially in wet weather or on painted surfaces, like pedestrian crossings, for example.
Brakes are all new with 3-400km actual run in time, so should be bedded in.
New IVECO 25mm dual master cylinder
Complete brake system from Holden AH Astra
NEW:
Cupronickel lines & all new flex lines except 2 front which are being fitted today.
Front Saturn Astra Calipers imported from US & same as Holden Astra [bought very inexpensively as wholesaler runout]
Front rotors & pads + rear rotors & pads ~ same reputable brand I always use
Front VH40 450psi in 1470psi out or 3.27 boost ratio
Rear VH44 450psi in 820psi out or 1.8 boost ratio
To pinpoint what was going on I had the vehicle roller brake tested yesterday & these are the results ~
Ideas & suggestions please gentlemen, as these brakes should be near PERFECT ~ but we are not quite there yet!
NEW:
