Um...... flipping the Diff is not really gonna work.
In a Dee box the helix of the gears produces an axial thrust on both shafts (top towards the front, bottom towards the rear)
The pinion against the crownwheel also produces an axial thrust on the bottom shaft, towards the front.
In the normal Dee setup the 2 thrusts are opposing, and therefore almost exactly balancing each other....... that's by clever design.
If you drive the box backwards, and flip the Diff, the 2 thrusts from the gears are reversed. So the bottom shaft now has 2 thrusts (gears and pinion) in the same direction..... and really significant.
The box does not have any bearings or structure designed to take such axial load, and would last....... well let's be optimistic.... 1 minute at full throttle.
Sorry Driven, your initial intention sort of got Dee railed.Started with one pic, 200 Posts and 3000 views later.
Aussiefrogs must continue somewhere.
It is so much fun
Now..... hang on a mo.Mmm there's not much to a VW transaxle either but in the early Kombis they flipped the crown wheel as the reduction boxes reversed it back to the correct rotation at the wheels, my brother's still running one of these in a mid engined sports car, the reduction boxes were removed and the whole engine and gearbox assembly rotated 180 degrees so the car still goes in the right direction. He's had it close to 40 years now?
Whether we believe it will last or not in the Citroen's case, will the crown wheel carrier physically flip over?
I guess the longevity aspect is just theory if
no-one has actually tried it?
Other option would be to turn the whole transaxle upside down, that'll keep you going in the right direction too with everything in the gearbox still spinning as designed.
It needs a caption......
Pete loves music.... maybe Shining Star? (Bowie - David not Dan)It needs a caption......
A duckling in the chookhouse?
Maybe..... "Chickendance"Pete loves music.... maybe Shining Star? (Bowie - David not Dan)
There seems to be some urban myths here.Lotus had a big problem when they decided to use a Dee based box.
They initially forgot (or didn't realise) that a DS engine turns opposite to almost all cars. It became a bit expensive to have Citroën produce boxes with the gears cut in the opposite helix.
Lotus used the Citroen SM 5 speed in the early Esprits. My older brother has two early Esprits, an S2 turbo, and an S1 none turbo.
Lotus knew exactly what they were doing, they chose an anticlockwise rotating transmission that hung out the front of the SM, placed a clockwise rotating engine on said transmission, spun the whole thing 180 and hung it out the back; thus retaining 5 forward gears. They picked the SM gearbox because they knew it ran backwards so therefore it was fit for their intended purpose.
The gear set and crown wheel and pinion are all standard Citroen SM. No fancy reverse cut helix gears, no special crown wheel and pinion. The whole lot was spun backwards to its original application. Oddly enough the gearboxes didn't blow apart after 1 minute of full throttle?
The weak point is the crown wheel which didn't take kindly to being driven on the coast side. There's a running joke among Lotus enthusiasts, "if you buy a used crown wheel out of an SM it's really brand new, as the back of the teeth have done no real work".
There is a mirrored crown wheel and pinion being produced (in Holland I think my brother said) to correct this improper meshing but the rest of the gearbox is still the standard SM gears being spun merrily backwards to what was intended.
My brother has rebuilt the box in his S2 turbo and he sourced all the parts from a Citroen specialist. All stock SM components.
As far as he knows the S1 box is still all original and untouched.
The turbo ones were more prone to final drive failure for obvious reasons, besides driving on the back of the crown wheel's teeth it was also try to cope with an extra 40hp over the SM's output.
Can't answer the supposition on gear angles?The SM box must be significantly different to a DS box.
Designed to handle a lot more hp, and to take sudden changes from power to overrun loads. Probably much flatter helix angles, and better axial bearing capacity.
The DS box is not.
Thanks Sven!!Doppelgänger of my wife? Wouldn’t that be funny…. That’s Kelly, my wife enjoying a glass of celebratory sparkling in the new Safari! Sven
