Talk of pfaffing around makes me think of sewing machines rather than V8s,
Roger
Roger
I just had a good IDea .....
Would have an unlimited range, in circles.I just had a good IDea .....View attachment 138171
Roger
A not abandoned beauty!
If I still had this benign Rover V8 I could have done a transplant.
His is the same as this, which is really his also! I'm just providing shelf space for it, sort of long term.I'm pretty sure Roger has a nice big leather machine that will outdo that one as well!
If a Mini can hold a Rover V8, surely a Cit cab also......
4.4L Cadillac Northstar was used east west.I have one sitting in my shed begging me to do this. If you manage to rebuild the motor to run "backwards".... that would be probably only the camshaft, oil pump and starter you would need to change... Then if you get an adapter plate and bolt it upto the gearbox, you then have the issue all of your accessory drive is now wedged up against the firewall.
Now if you can find a vehicle that used an small all alloy v8 in east/west configuration, you would have the accesory drive in the right place and would just to reverse the motor and work out an adapter plate.
The only sensible conversion I can think of is finding a tesla and tearing out it's motor and battery pack. electric motors don't care which way they turn
Before they released the Austin Tasman/Kimberly 6 cylinder range Leyland Australia built some V8 test mules with this body shell.There's a transverse Austin Princess manual box mounted underneath, as in the Austin. How it handles the torque I don't know.
If you have driven a manual Rover 3500 S - it isn't wheezy.
The P6 3500 autos weren't exactly slugs either.If you have driven a manual Rover 3500 S - it isn't wheezy.
Um...... flipping the Diff is not really gonna work.4.4L Cadillac Northstar was used east west.
Now I couldn't find as clear an image as I would have liked, but it almost looked like in the photo I did find that you could flip the DS crown wheel carrier over and drive it off the opposite side of the pinion? Has anyone physically tried this cos that'll get you heading in the right direction.
That’s a very sensible conversion because then you’d have a Tesla that actually looks good on the roadThe only sensible conversion I can think of is finding a tesla and tearing out it's motor and battery pack. electric motors don't care which way they turn
Mmm there's not much to a VW transaxle either but in the early Kombis they flipped the crown wheel as the reduction boxes reversed it back to the correct rotation at the wheels, my brother's still running one of these in a mid engined sports car, the reduction boxes were removed and the whole engine and gearbox assembly rotated 180 degrees so the car still goes in the right direction. He's had it close to 40 years now?Um...... flipping the Diff is not really gonna work.
In a Dee box the helix of the gears produces an axial thrust on both shafts (top towards the front, bottom towards the rear)
The pinion against the crownwheel also produces an axial thrust on the bottom shaft, towards the front.
In the normal Dee setup the 2 thrusts are opposing, and therefore almost exactly balancing each other....... that's by clever design.
If you drive the box backwards, and flip the Diff, the 2 thrusts from the gears are reversed. So the bottom shaft now has 2 thrusts (gears and pinion) in the same direction..... and really significant.
The box does not have any bearings or structure designed to take such axial load, and would last....... well let's be optimistic.... 1 minute at full throttle.
