Another option is to fit an 1.9L 88mm crank/rods, GTi manifold and GTi cam to your existing engine and upgrade the ECU. It retains the same engine number and removes registration issues.
Also i wouldn't go grinding into the body deadener too soon unless your 100% sure its a bodgy repair. they can look like this from factory with a bit of a clean the body color is revealed in the under guard area on most if not all of the 205's ive owned
If the dash transplant doesn’t work out I have seen some neat gauge pods floating around the inter webs that are 3d models that can be used on a domestic printer - they then sit in place of bits of dash like the coin tray. I’d send the link just can’t seem to find it againHi Steve,
In short - slowly . Winter in Tasmania has slowed things down (I don't have anywhere to work on the 'Pug that I can heat) and it's cold enough that you don't notice where you left skin behind in the engine bay until you wash your hands later.
I've managed to get a GTI Instrument cluster (in fact several - thanks John!) and there may be a few issues I need to work through with the electrics. I pulled the Si cluster out and plugged in a GTI cluster in its place but basically nothing worked (not even the tacho) so there may be a fault in it somewhere. I really want to replace the 'idiot lights' for oil and cooling with gauges, so this will likely need some further dissection on the kitchen table.
Likely the smartest thing to do will be to partially dismantle the existing cluster and swap out the oil and temp gauges.
I suspect that the issue may not just be the instruments, but the sensors. As mentioned previously, the sensor on the oil pan has no lead connected (or even dangling loose) and the radiator sensor was unplugged when I bought the vehicle so someone may have been trying to diagnose an issue. The thermofans cut in when the engine gets warm, so at least the important parts work. I keep forgetting to take the relevant pages from the workshop manual into OfficeWorks to get them printed on A2 so I can read them without a magnifying glass.
The flexible printed circuit board on the back of the instrument cluster does have me a bit worried (stupid design decision) so warmth may be needed to stop both it (and myself) from cracking due to the cold.
I also picked up a Japanese GTI instrument cluster (photo below - sorry about the reflections but the curved plastic makes it a challenge to photograph). The white plastic is crumbling (possibly UV damage), one of the mounting brackets is missing and the flexible PCB looks largely shot so some careful repair work may be needed if I end up using it. It's very legible, and the gauges have a 'recessed' look so an interesting alternative to the usual
On the issue of the 405 rims - well it looks like the wheels rub on the bodywork at the rear. The 195/50R15's may be too wide for the axle, but 185's would look odd on the rims. I've put a pair of 5mm spacers on the rear wheels as an interim (fixed the rubbing there) so it looks like it's fixable. They also rub on the front on full lock but I can live with that (not like it's a difficult vehicle to park).
Longer term I'm not 100% clear on what to do about this - I've seen a couple of sets of Speedlines come and go on Gumtree, and I'm beginning to think I should have bought a set as a contingency. Maybe a new/rebuilt rear beam would help ?
I'm still looking around for a 1.9L crankshaft and conrods . Once I have those I can look at getting a rebuild kit and give the car some horsepower back (the factory 66kW seem to have disappeared over the past 30 years ).
My priority at present is to get my tax return sorted out - the cheque will likely go towards buying fuel injection and an ECU and retiring the monopoint injection. The idea of rebuilding the engine and upgrading to fuel injection at the same time sounds like not much fun - I'd rather do this in small steps changing as little as necessary along the way.
I'm still undecided re who/where to drop the engine and get it sorted. I've the name of a local mechanic/shop with a good reputation with Peugeots, so I have options.
There was an interesting couple of posts a while back (from PeterT if memory serves me) discussing issues with rot in the alloy blocks a while back. I never thought of this, and I'm hoping that there are no issues with refreshing the cylinder sleeves otherwise this may become an expensive issue to sort. Still, no use worrying yet.
Either way the car gets driven weekly so it's not going to die from neglect.
Sean
Graham is correct here. The GTi tacho has a filter to remove the 400V back emf from the coil. Use the 85/86 connections (coil) of a relay to fire the the tacho. It works a treat. Matthew suggested this in another post recently (kudos to him). Remove the mechanical side. I suggested the same recently on 205 Forum:S1/s2 tachometer won’t work in an si. The gti one uses high voltage on the coil primary.
Neither will s3 tacho work as it also uses a coilS1/s2 tachometer won’t work in an si. The gti one uses high voltage on the coil primary.
Have you isolated the filter components peter? Would like to add them to my Si tacho in the 309.Graham is correct here. The GTi tacho has a filter to remove the 400V back emf from the coil. Use the 85/86 connections (coil) of a relay to fire the the tacho. It works a treat. Matthew suggested this in another post recently (kudos to him). Remove the mechanical side. I suggested the same recently on 205 Forum:
Ever fitted an Msd or other brand ignition box with the stock ecu setup?
Hey everyone. Has anyone in group successfully fitted an Msd or another brand ignition box to the stock setup with the tachy relay, ignition amp, ecu and coil? Im trying to fit one but not entirely sure why Im getting no spark. System works as expected when the msd is not connected. This is on a ...www.205gtidrivers.com
You won't know how much corrosion is in the block until you strip it and get it bead blasted around the liner seals.
If you add the 1.9L crank and rods, GTi inlet manifold etc., GTi cam, in addition to an aftermarket ecu, it will be a very nice engine.
I’m confused. The circuit described is for use with a GTi tacho.Have you isolated the filter components peter? Would like to add them to my Si tacho in the 309.
