- Joined
- Aug 2, 2000
- Messages
- 11,485
Standard rear shocks are made by AP in Yugoslavia and are actually quite good and do give a bit more travel than the GTI ones.Day 11 - Off in a Dash
Today was a continuation of yesterday. I've finished patching the top cover - there was a three way fracture that I needed to fix with Araldite and a bit of fiberglass mat to keep it rigid but it looks and feels solid now
The small top box in the dash has a rubber gromit - looks like a previous owner had a gauge or similar and used the gromit to neatly plug the hole.
While the dash is in pieces I'm looking at another fault listed on the last service receipt
"The horn is not working and suspect the switch on the horn pad. Would require an auto electrician to diagnose correctly"
I've tested every single fuse I can find and they are all OK. The Horn fuse should be 25A, but someone has installed a 30A which isn't smart and from looking through the Haynes workshop manual the 205 does not use a horn relay but switches 12V directly form the horn 'button' on the steering column.
I do however have a theory ...
Alarm, Alarm ...
There was a loose wire dangling out of the lower storage bin next to the drivers right knee. It 'led' up to a LED mounted in the dash, so it would appear that a previous owner had a car alarm installed that was later removed. One of the wires just ended in mid air connected to nothing, while the other trailed off via the centre console (changing colour) and exited via the firewall into the engine bay. That end was just a bunch of frayed wires, so it looks like whatever was there was torn away.
You will note that someone had previously wrapped the wires with gaffer tape after twisting the ends together, and decided to change colours from red to black.
There was another pair of wires wrapped in electrical tape protruding from the instrument pod on the steering column. I pulled the plastics apart (not the first person here - it was held together with black silicon, and include an old rubber band and a ring pull for luck). According to the Workshop manual the wires were connected to the left and right indicator circuits, which makes sense if the alarm needed to flash the blinkers. I removed and re-insulated the wires to return it to match the manual.
I also found the ECU screwed in its correct place up under the dash. Interestingly someone has tapped into part of the ECU loom (quite heavy gauge wire so possibly power) and the cables were wrapped in electrical tape and routed through the firewall into the engine bay. They terminate on a relay near the fusebox by the bonnet hinge (definitely not original) so possibly the alarm was able to kill ignition or the entire car as well.
So following Occam's razor my working hypothesis is that there is either an in-line relay to the horn that has failed or damaged wiring that has deactivated the horn. I've got the car up on ramps at present so I'll hopefully get this sorted tomorrow.
Wheels, Tyres & Suspension
I rotated the tyres today to put the best tread at the front. Not completely happy with this as they are dated 2008 so well beyond manufacture recommended lifespan so it looks like I need four new tyres and better rims to match.
Looking at the fantastic stiff on the '205.si' site I think a set of 15" rims would do the trick. There are some great looking pugs with these in pictures on the 'net so will probably do that.
The suspension is definitely getting old. The front looks and feels fine at present (Record Maxigaz dampers) but the rear are unknown - no markings visible.
I'm guessing these are the originals.
Keys
Well surprise - in Hobart getting keys for a Peugeot is not as simple as a Holden. I currently have just one key, so a couple of extras would be a smart thing to do.
The young lady at Jacksons Locksmiths was very helpful. She wasn't 100% sure what blank to use, so she cut me a key for free to take home and try. Turns out it works perfectly, so I'll go back for the second and pay for them both. It's nice together such good service these days.
Thanks guys for all your help and suggestions on this.
Sean
