correct
Its not a home mechanic replacement but spares are available. Easier to swap the VB with a second hand unit.Thanks heaps. Where do I find the cover bush that you're referring to?
If the gear indicator blinks, the multi-function switch on top of the gearbox is not aligned.So I just replaced the two main solenoids and put everything back together. I was very careful to line up the manual valve and the spring.
However, when testing it, it was struggling to find Drive. It would either blink N or R, but when I did get it into Drive, the STOP started flashing.
Any ideas on what may have gone wrong? I checked that the two solenoids I replaced were black top ones, ie like for like.
Does it maybe need time for oil to flow through the valve body again, and the issue will go away?
Please help! Thanks so much!
Snow and sport icons flashing means the oil counter needs to be reset. This needs to be done at every fluid change which in PSA terms is never as these boxes are sealed for lifeI just reinstalled the roller spring and checked the gear indicator. Seemed fine so I reassembled the car.
Then the antipolution fault and abs warning came on! I checked the spark plugs and the warning went away. Also after driving, the abs warning went away.
HOWEVER, the gearbox warning came up a coupe of times when driving and flashed the snow and sport icons for very brief moments and went away.
The car cannot seem to use the Manual up/down but other gears are fine. Also, I feel like the transmission is either slipping or in the wrong gear when the car was warmed up because it was revving too hard and not going very fast after coming to a stop. My OBD2 says coolant temp fluctuates from 90 to 98. Is this normal, or is somehow the ATF overheating and causing the transmission not to work properly!
Any advice is greatly appreciated as I really need this problem fixed. The car cannot be driven like this!
Thanks everyone
Hi, I helped Pug88 with this issue, both of us being new to older European auto transmissions we went through what we thought was a systematic process - noting that the first gearbox had a mechanic change the two main electro valves and check the box, then giving us a diagnosis of a worn internal oil pump (gearbox @ 118k kms), which sent us down the route of changing out the box with a box from a car we had as a spare with relatively unknow history. Also worth noting we're in Australia, NSW.
Sequence of events:
1. Original gearbox goes into limp mode. (let's call this C1 gearbox)
2. Mechanic changes "main pressure regulation valve" and "convertor pressure valve"
3. Mechanic makes the call that after changing valves that the internal oil pump is badly worn.
4. We have a spare car with 200k kms on the clock. (Citroen C4 2007, identical car, even the same color)
5. Remove gearbox and install it into our car ((let's call this C2 gearbox)
6. C2 gearbox now in car and has an issue changing from 2nd to 1st.
7. Symptoms lead us to believe is may be an issue with valves 3&4.
8. Remove valves from C1 Valves and install into C2 box.
Note: at this stage we have not removed the valve body, only harvested valves 3&4 from C1
9. Carry out ATF oil changes, 4 off oil drains and fills to get the ATF as clean as possible. C2 is running better but still has the initial fault of hesitating from 2nd to 1st.
10. Add Lucas Oil Transmission Fix (24 oz) - C2 runs better but the issue is still there.
** Pug88 has purchased the Lexia3 and we've carried out as much checking as possible.
** we also swapped the gearbox computer out from the donor car to see if that was an issue - no change.
11. At this stage we concede that the box has a mechanical issue and is most likely a worn transmission brake band.
Then comes the lightbulb moment, I decided to pull out the valve body from C1, I had always had a question mark as to why would a box with only 118k kms would have a worn pump? I was also going to split the box, pulling out the valve body I find that the two electro-valves the mechanic has changed are "loose", and by loose I mean finger tight. It appears he has installed the two valves, probably been called away or distracted, installed the valve body, run the car, tested with his analyzer and diagnosed low oil pressure. As the gearbox was run with the valves loose, the oil pressure bypassed the valves and blew out the seals / seal covers.
This is the point where we head down a rabbit hole of changing out and re-changing out gearboxes. After discussion with the mechanic, and I'll say he was very apologetic and possessional about it, I asked for 2 new valves, and the money back from the original service, he was compliant and we left on good terms. So I now have two new electro-valves and enough money to by $150 worth of Penrite FS ATF.
Remember at this point we still have gearbox C2 in the car, C1 sitting on the ground with a valve body with two faulty/incorrectly installed valves.
12. Install new electro-valves to valve body after giving it a clean and once over.
13. Install gearbox C1 (original box).
14. Carry out ATF fluid changes.
And a hint, Removing the front subframe does make changing the box out easier, I did two changes with the sub frame in and 1 with it out.
Car has now been running for over 800kms with no issues, gearbox changes are smooth, and the box is behaving like you'd expect a 2006 4 speed auto to behave.
It's a pity we were between a rock and hard place (we'd only had the car for 6 weeks) when we first got the diagnosis of a worn oil pump post valve changes, at that stage we couldn't find a 2nd hand box with warranty - wreckers hotline had one is SA, but it would have been a $1800 outlay, a rebuild was quoted at $5k. So the only option for us was to take a chance on the donor box C2.
So in summary, a mechanics (independent French car specialist) mistake lead us to remove C2 gearbox twice, C1 gearbox twice (once because I dropped a convertor bolt behind the flywheel on install), and install a box 3 times. We certainly know how to change a C4 AL4 auto gearbox now. Thanks for all the input from the froggies.
This closes the chapter (hopefully) on our gearbox issues!
Hi all,
I recently picked up a 2006 Citroen C4 Auto, the car drives fine until after some period of driving (say 30-45 minutes) the car will begin to lose the ability to "creep" forward from a stationary position, i.e. If the car is stopped on a flat road, letting go of the foot brake will result in no forward motion (creep forward). If I give it some throttle, the RPM will rise (higher than usually required) and it will eventually bite/bump/clunk and drive off. If I repeat this process multiple times it will eventually become nearly impossible to get the car moving in 1st (will needs lots of RPM to get the bite), the only way to get the car moving is going to "Manual" mode and putting the car into 2nd gear.
Does anyone know what my next steps are to troubleshoot this.
J.
You don't need the tool. Set trans into park, that;s the furthest the shift linkage will ever go.Thanks dimistyle. All I have is an OBD2, which does not show gearbox temp or gearbox oil pressure. Oops I put down the wrong location when I signed up as I used to be in Sydney!
I'm considering buying the EMV and EMLU for $65 on ebay and swapping out along with taking the valve body apart for a good clean... However, I don't have the roller blade tool required to finish the job.
General question if anybody knows, what threads does the tool have on it? I could buy a bolt to replicate the tool.
Just need the roller blade tool and a small torque wrench and should be good to put the valve body back together after taking apart from what I gather.
Also I forgot to mention to disconnect the shift cable when adjusting the blade set, whatever method you use. The cable should reconnect without readjusting if it was correct before. And dont forget to check the neutral switch setting. Cheers again.You don't need the tool. Set trans into park, that;s the furthest the shift linkage will ever go.
Set the roller blade to engage into the appropriate recess of the shift arm and tighten.
Check that the arm has not been moved [which happens when the blade is compressed during the tightening of the screw]
Pull the blade clear and move the linkage back and forth, then return to park position.
Ease the blade back into position and check that it fits correctly into the link without moving the arm.
And then the test to see if you got it right
Move the gear stick to a different position and note that the roller is sitting correctly in the appropriate notch. Simples. and Cheers.
