I had a thought about what shanadoo said it makes sense that it would be having problems with the E1 clutch. My issue is in 1st and reverse only. The only other common component is sunwheel 1 P1 but if that was the problem there would be heavy shudder while driving.
I am actually pretty happy to make this discovery because I can now rule out the brake bands! It means I somewhat have the possibility of just changing out the clutch packs. However I would need to source new clutch packs and correct tools for the clutch replacement. I only have the tools for the clearance checks.
I will add the lucas additive before I look at the clutch pack change.
By the way I thought it was very easy to deal with the roller blade by leaving the gear selector in park, scribing the position on the gearbox and disconnecting it so that the roller blade was free to rotate. A bit of preload on the leaf spring bolt that is supposed to be tightened to 9Nm (say at 3Nm) and it is very easy to rotate the roller blade into the correct setting for park by hand provided the gear selector is disconnected. Tightening further to 9Nm doesn't make the leaf spring bolt jump off. A quick check confirmed that the scribed mark was aligned just as before I started disassembling.
Also the torx heads do not have a deep insert and can be easily stripped, even when torqueing to a mere 7.5 or 9Nm! This especially can happen if you are fooled into using a torx 30. Be careful! The correct bit is torx 35 which is not very commonly used compared to torx 30 and torx 40. Think of a 7mm hex head vs 6mm and 8mm hex head. The torx head bolts are all similar to each other and can be replaced by a 12.9 exact length cap head M6 bolt 1mm pitch with a washer if the torx head is completely stripped out.
No fault codes as I only have OBD.Maybe, I missed it, but did you read any fault codes from it?
