Apply 12V to fuse 10 (both sides one after the other) still wont start.OK, must have been an error when you measured 12v on fuse 5.
Do you have any crimp spade connectors?
Next step is as DMC says, putting 12v onto fuse 10 from another source to provide power to the injectors and then crank the engine to see if it starts. If it does, remove the wire to stop the engine (ign key won't turn it off).
