Hallelujah! Praise the lord! The gearbox is out!
I/we tried rotating the gearbox so as the stud would clear the body work. Lack of strength or ineptitude, this wasn't successful but we did reconnect the gearbox back up to the motor. Haynes advises to use a stud remover if it's too tight for a spanner which was the case. Unfortunately, you can't get a stud remover down onto the stud due to the engine mount bracket immediately above it. Anyway, and I hate to do this, a pair of vice grips proved the solution. We didn't have to cut off the stud, it isn't pristine, but should clean up okay - I think.
With the gearbox out, we took out the thrust bearing, fork, pressure plate, driven plate and flywheel. Having worked on many 504s, it was a real surprise to see how small the thrust bearing on a 406 is - and part of it is plastic! The clutch plate has even wear, but clearly needs to be replaced, but the flywheel and pressure plate look like they have been a little hot.
Next week, I'll price the parts needed. I'm a little concerned about the flywheel. No score marks but some discolouration. I don't know how common this is. I'll replace the thrust baring guide sleeve, as dmccurtayne advised, particularly as the thrust bearing has worn it on one side.
As always, very happy to get advice from more knowledegable others.
