I can imagine that. We opened an office rather more recently and it had changed...... Any of us who have spent any time there are very lucky.Around about 25 years ago i was working in China for an R and D Aquaculture company. We hired 14 employees for 12 months for around $40.000
AUD.
Very neat Stan! I wish mine were as neat behind the dashboard.As part of my 12v conversion, I installed a small DC to DC converter to power the petrol gauge and the temperature gauge. The petrol gauge positive terminal serves as a connection point for switched power from the ignition switch. I had to make an insulated terminal assembly to replace it. I don't have the gas tank installed, but I hooked up the sending unit and the gauge works perfectly. I will use a larger converter for the Sofica motor and a resistor for the wiper motor.
That's one neat and sophisticated system for a 4CV.I mounted a PCV valve on my Autobleu manifold. The valve is one that fits a three cylinder Subaru Justy. I wanted one that was used on a small engine, and the Subaru Justy PCV valves are very inexpensive (probably nobody wants them). The PCV valve will be connected to the valve cover and the valve cover will also be vented to the carburetor air intake - probably at the air filter. I will make a oil demisting assembly inside the valve cover using stainless steel scrubbing pads to remove oil from the crankcase fumes. It will be similar to the assemblies used inside later Dauphine valve covers. The PCV system should work exactly the same as ones on the late Dauphines and R8s.
View attachment 130069View attachment 130070
Hope he's addressed the braking issue........... We have a couple of road-going 4CVs in Oz with 16TS power and they go fairly well.
Nice project for someone - I imagine he did the conversion well, back in the day. Our 16TS friend could swap stories! His car is fully approved, engineering-wise.Brakes are fine but the front gets light on a power shift, to the point that steering is not possible for a split second. It's been off the road for 30 years.
We've had the discussion about those pressed-in steel pipes on SEV fuel pumps, haven't we?I made gaskets for my Autobleu manifold. I have not seen this gasket for sale anywhere, just pictured in the parts manual. I would have made one anyway, the material is not expensive. It is Fel-Pro 3009 - good for high heat. My fuel pump is ready for assembly.
View attachment 130274View attachment 130275
Good re pipes! I've not used 4A myself. BAR and AVP have been erratic in replying, so I'd not wait more than a few days. Sometimes good, sometimes not. With BAR, I ended up getting a friend in Paris to ring them on one occasion!Yes, we have discussed the pressed in pipes. The ones in the fuel pump are very tight, couldn't move them a bit.
I seem to be having trouble getting a response from Bretagne Auto Retro, AVP and 4A pieces. Anyone know how long I should wait for an answer to an email?
