John,By the pic you can see that there is a small rod with wing nut to the transmission drum linkage at the bell housing where I have removed the small cover plate.
The foot brake shaft goes from the right to the left and links to the rod going to the back of the car.
Hope this helps.
1923 B2 - - John
Many thanks for that, it helped a lot!
I have enclosed a pic of the 5CV setup along with your B2.
There are differences in both models, but the brake principles are the same.
All I have to do is fit a lever on my foot brake linkage to pull back like the hand brake does.
Then make the hand brake pull up the gearbox brake, instead of the foot brake pushing it down.
Now I know how my Father did it. He was lucky enough to have many spare parts that would have made the pull bake lever easier to make.
Thank you so much.
Ron
