What we called in the Army, a first parade service. Not that everyone did it in so much detailI was flicking through the Carry van's owner's manual.
Suzuki sure think their vehicle buyers are a dedicated bunch.
We had forklift checklists that the operators called a "tick and flick". The reality was, if it moved it was considered "fit for service".What we called in the Army, a first parade service. Not that everyone did it in so much detail
Hi guys,
The 5CV that I bought, is now safe and sound in Brisbane. It survived the long trip from Renmark to Moss Vale, then Moss Vale to Brisbane in very heavy rain.
Last time I drove a 5CV was when I was 16 tears old.
Now that I'm 72, I have discovered that things are not the same.
I cannot get in the drivers side door like I could as a kid. Have to get in the passenger side and slide across
I'm missing a part that maybe very hard to find, a speedo cable. The speedo is driven by a couple of cogs on the front wheel. I will probably have to get one made for it.
Anyone have any ideas?
Some pictures of the transfer.
First is loading up at Renmark, then me lashing it down on my trailer in Moss Vale, NSW, and the car itself.
Ron
Flexidrive at Coopers Plains will make you a speedo cable to your design pronto. Cheers.I'm missing a part that maybe very hard to find, a speedo cable.
For speedo repairs see Lionel Otto Instruments, Evans Road Salisbury, Brisbane. Been there for centuries or so, they'll test and repair.I can do one better than that. Just took a photo of it. The fact that the needle is below the stop, it doesn't give me a warm feeling about it's condition. The guy I bought it from said it had done 48,000miles. Speedo doesn't reflect that.
Thanks, mate. I'm try and take it in tomorrow or Tuesday. Eventually got it out of the car. It turns and the needle moves, so that is a start.For speedo repairs see Lionel Otto Instruments, Evans Road Salisbury, Brisbane. Been there for centuries or so, they'll test and repair.
Sure is MPHI suppose the calibration of the speedo needle would be set by the rate at which the odo clocks over. seeing it is geared off the cable. I would suppose the odo is set to record miles so the speedo would read miles per hour.
Cheers, Ken
John Robertson bought it off Lionel and kept the name.Lionel Otto thats a name from the past.
John was saying it is a complex speedo, but very efficient. There is a governor inside with springs attached, that spins up to 2000rpm.I suppose the calibration of the speedo needle would be set by the rate at which the odo clocks over. seeing it is geared off the cable. I would suppose the odo is set to record miles so the speedo would read miles per hour.
Cheers, Ken
Yes it is. There is no area for a seal
Many thank. I looked that up and it is similar to the workshop manual that I have. Also in FrenchI found this while looking. You may have it already, otherwise here it is
Sorry I mucked up the attachment. Too big also
It was "Guide de l'Amicaliste 5HP" Yell if you want it.
