Which shaft is that, David?That shaft has been reclaimed using hard chrome.
David, do they do that instead of using an oil seal ?I answered your question Ron but it did not come up, the edge of the front main bearing, there is a rough surface, this is the give away, the shaft is ground under size then built up with hard chrome then ground to required size, common practice to reclaim shafts in the power steering business.
Many thanks for that. It works, I can read Depanoto in EngrishFrench should not be a problem if you locate 5CV information. Any PDF with normal text (not text in an image) can be reasonably well translated by https://translate.google.com.au/?sl=auto&tl=en&op=docs
Select the document tab.
Websites can be converted into printable format by most browsers, and then "printed" to pdf, ie saved in pdf format on your computer. Some browsers, eg Vivaldi, will translate the site as soon as you visit.
Hi Ted, yes it could be a good idea.Hello Ron, I have been watching your progress and congratulations on a good job. I am in Melbourne and understand there are several 5CV owners independently looking to re-create the first circumnavigation in 2025. Do you think it would be a good idea to get all interested parties together here on Aussiefrogs to establish a co-ordinated event ? Depends if you are interested in this celebration or not. Ted Cross Melbourne CCOCA past president. 0400592208
Ok I will try and reach some other prospects and see if we can get a consensus of how to go about this.Hi Ted, yes it could be a good idea.
Ted, first, contact Gary Harrowfield, on 0418 508 244. He is part of a team the are going to re-enact the 1925 Trip. He is also looking to purchase a 5CV for that trip.Ok I will try and reach some other prospects and see if we can get a consensus of how to go about this.
Michael,I drive the B2 Citroen into town when the weather is good. The brakes are excellent for this small car.
I use the method of pulling the "handbrake" to slow down and as I do this, I already have my foot on the brake pedal ( transmission drum brake ) to bring the B2 to a stop.
This works well and doesn't put too much stress on the "drive - line".
Brother John's B2 has the brake handle and pedal swapped around.
You still need to use both systems, as to use just the one when stopping would put to much load on either the rear brakes or transmission drum brake.
The universal joint on the rear of the gearbox is a flexible canvas type so with heavy use it would need more maintenance.
Ofcourse it doesn't have the luxury of front wheel brakes, and hydraulic brakes were something of the future.
Michael
Could not get past the first lot of photo's on the restorationI came across the site of a French bloke who restored a 5CV from 1924-
There's an annoying popup that should be suppressed. His introduction is at
French isn't a barrier now!
Yes I did later find a way to see the pics. No change in braking system.Just went there using Vivaldi. There are 14 pages with 4 or 5 small photos per page. They have an arrow to proceed to next or previous.
By the pic you can see that there is a small rod with wing nut to the transmission drum linkage at the bell housing where I have removed the small cover plate.Michael,
Could you possibly find out for me, how your Brother John's car, had the foot brake transferred to the rear brakes?
I need to doo that to my 5CV. I remember my old man did it to the 5CV buckboard on the farm. Can't ask him now, he has been dead for a decade. Photos would be a great help.
Ron
