With the work on my D Special progressing. I now see the need to remove the roof and re-seal leaks.
http://www.aussiefrogs.com/forum/showthread.php?p=935368#post935368
I've never taken the roof off a D, and as I understand it, mine is the bonded stye rather than the bolt on roof. I've had a look at Tony Jackson's PDF and am still a little wary!! My car has a Webasto style sunroof (vinyl top slide back type) this is mounted with what looks like a black anodised frame.
My thoughts are that I would leave the sunroof in place when removing the roof, it should give the fibreglass roof a little more strength than if it were not there?
Questions
Once I have removed the trim, 5(?) bolts, how easy will breaking the seal and lifting the roof be?
Can I re-use the external rubber seal which appears to be in good condition?
Do I need to remove the windscreen (I have a new windscreen rubber)?
What now is the recommended sealant when replacing the roof (brand and product code whould be appreciated - not just Sikaflex, there is a huge range of Sikaflex products)?
Any tips on removal and replacemnt of stainless trim.
Are there any parts that I should order now before removal?
I'm sure there will be more questions, thanks in anticipation :wink2:
Chris
Questions
Chris
