F
farmerdave
Guest
doggiedog said:If you look at BPs site and look for Xantia lubricants, they specify Dextron111,
but if you go to Mobils site they specify their ATF220, which is Dextron11D,
which rings a bell, cos older Fords used a different ATF, from memory.
Although if the Xantia is a V6, it states it is filled for life, and to use manufactures part number Part No. PR 9736.22.
http://www.mobil.com/Australia-English/Lubes/PDS/GLXXENPVLMOMobil_ATF_220.asp
Which is all very interesting, because mobil ATF220 is one of the specified fluids for ZF bus transmissions- and was listed by the Regie as an alternative to the old renaultmatic versions 1 and 2. It is a low friction modifier oil.
The comment about a glycol base has me even more concerned- glycol is very good at dissolving certain types of friction plate.
I guess this means I'm up s***t creek with the 405.
Farmerdave
