da_prancin_schu said:If you are looking for a good VTS, how about new. They can be picked up for $26K Drive away now... unbelievable value for a new car! I'm considering it now.....
Thats for sure! I had a long test drive in the C4 saloon 2lt auto and I have to say that I was terribly dissappointed with its build quality. . As mentioned in other threads the plastic assembly surrounding the gear shifter can only be described as shocking. Parts so loose and ill-fitting you think they were added on from another model. I've seen better quality in asian makes. :nownow: The paint job on this particular car was full of "peal" and many different rattles could be heard over changing surfaces. In all, very sad.
However, once back in my Xsara VTS, the immeadiate impression of quality and build was so noticable why would you spend $40K on C4 when for $26K you can score a well screwed-together Xsara VTS
Cheers Pete
