Well that is another improvement that can be made is the mark out (using a Sharpie) where the to set up the measure tapes. I measured with a 6 inch rule.Ah, now I get it. I should have looked at the link before. Hadn't realised there was a corresponding board on the other side. Repeatable and can work anywhere. One fiddly bit is measuring it where it's meant to be measured. Toe-in/out is really an angle, but mm is more convenient. 4mm at the tread might be 3mm at the rim and 2mm where you measure it in the new gadget.
Thanks for the tip on FWD. Good to know.
Have fun,
Rob.
