Under the NBN neither modem nor router control the maximum speed. It is set by NBN depending on the max speed you pay for.
If you have a fibre connection, you only need a router, HFC services are converted by the black NBN box to feed routers; FTTN and FTTB need a VDSL modem to convert and trouble can unexpectedly occur here at the moment
NBN is very particular about modems on their lines, and lately has been checking the MAC address of connected units, which is visible to them, to ensure "NBN compliance" (as defined by them, not as stated by the manufacturer) devices are fitted. MAC addresses give away the maker and model. They intend to act on this and at worse will block you. See also https://www.nbnco.com.au/learn/device-compatibility/vdsl2-modems
One safe way to ensure compliance is to use modems supplied by your provider, who have always had them approved. These invariably are combined modem-wireless routers with extra capabilities such as VoIP. All landline phones now run as VoIP. IF you have a service type that doesn't need translating the modem section is preset to disabled. Providers usually preconfigure them for you as NBN standard VDSL is a pain to set up..
(VDSL is an analogue signal, as was ADSL. Routers require a digital signal, hence the conversion by a separate or built-in modem)
