Ropes said:Ater a study of things, this is what the book says.
Up to eng. 6565353 it seems there is no scavenge pump. After 6565354, which it says is 1980, there is a scavenge pump.
My eng no. is 6568353, suggesting it's a later engine in a 79 build car.
It's quite correct when it says the main pump will be very noisy if the scavenge pump is not working. I haven't yet checked the pre-filter which causes the same symptoms apparently.
so long as a pump in a tank has not bieng subjected to low fuel levels it is rear that they will fail
they need fuel to keep them cool hence i have never run either of the 2 cars i have had with in tank pumps low
that is the 405 and the 306 which i have now
i do know that in the 504 TI's i have had when the filter starts getting blocked the pump gets noisey and if left the car will starve of fuel and miss
if you keep going the car will just stop
my father had this a few times in the early days before he realised what the problem was
all a pump in the tank does in something like your 604 is stop fuel surges when the fuel moves around in the tank away from the pick up
we had this problem in a scorpion we put injection on and instead of running and in tank pump we ran a surge tank just before the main pump
that cured all the fuel surge problems and we didn't have to pull the tank apart to put a pump in the tank
