See advert in parts.......
May have one but...See advert in parts.......
Having done the conversion - I'd look at this........The rod guys are converting their cars to Electronic Power Steering
Apparently a Prius one is a great candidate
You keep the original rack but splice in an EPS system by shortening the steering column
Lol, your making me feel older.Shoj, I have Dialogys and could look it up there for you if you give me full details on the two Renaut ID plates(stickers) and it should give a definitive answer. But that will only work for the original rack fitted at the factory.
BUT I am very busy currently and that program is a PITA to use so it needs some time to spend on it. It is the worst program I have used and i am not good with it. I think it will go that far back but have never used it for something that old !
PM me the details if you do not want to put them here.
jaahn
You still want a power steer rack though for the ratio... But I wonder if a (electric steer) Clio rack could be made to fit...The rod guys are converting their cars to Electronic Power Steering
Careful...sounds a bit scammy...why would the seller not reveal the part#?Thanks SunRoof!
But the seller is playing hardball. He won't give the part number until I pay for it and then if it's wrong I have to cancel the order.
The pic is only one and it could be anything.
Who's wrecking a Fuego out there?
why i mentioned this....Careful...sounds a bit scammy...why would the seller not reveal the part#?
fair enough. its been a long time since i spent any quality time under a Fuego dash Wonder if a Clio Sport hydraulic rack could be adapted then...As mentioned Haakon, It's just harder and really no room when you look at it. I have the column out and the pedals are part of this. The fuse board is under as is the heater box. major mod to the column would change it and may engineer it wrong!!
We are but there is already dibs on the power steer rack. And if we had two I'd take the other.Thanks SunRoof!
Umm,got eldest sons 2.2 rusty fuego here which he wants to get rid of but don’t think he wants to part it out,has power steering…the old distance problem again john….jimThanks SunRoof!
