:roflmao::roflmao::roflmao::roflmao:
Rob, Pyro? Your showing your age, it hasn't been used in decades. I was lucky to use it a half dozen times when I was a boy, but not since.
Rob if you want to read the regs you wont find it at ecables, I have a copy of AS 3008 you could borrow.
Which of the over 200 do you want, as there is a number of factors to take into consideration not just the ones you quoted. If you want to borrow and have a read fell free to go to my place in Melb and pick up as I'm in Collie WA at the moment.
Voltage DROP & copper losses
You know ohm's law and all that irrelevant crap?
Have you ever heard of cable de-rating?
They way cable is specified by the percentage voltage drop, ie the with full load current flowing in the cable. The max voltage drop across the cable should be no more than 2% of the applied voltage.
http://www.ecables.com.au/?page_id=85
OK so the maximum allowable is 5%. I always designed at 2% because the equipment we used was quite voltage critical.
Read the regs....
Do you mean this? Compared to this
(b) Voltage drop-- dependant upon the impedance of the cable, the magnitude of the load current and the load power factor.
Rob you mention two things that are in part (b) there is still parts (a & c), and cable de-rating I can't see that mentioned.
Really though Rob, you are a clever person but to keep referring to documents is a bit unfair, I'm only going on with what my drug and alcohol infected brain can remember twenty odd years ago.
Rob I thought we were finished this afternoon, but really I don't disagree with you, I'm just surprised you would persist with something when all I was trying to relay was that variations in supply voltage are not considered and voltages stated as standard are what is needed to do any calculations within the industry. Yes the actual voltage is important under certain conditions or faults to be used for calculations but generally speaking it is 230V and 400V, which is what you would not acknowledge.
So if you can accept that 230V and 400V are Australian Standards, I'll admit that I didn't always quote all that you said when you were in the ball park. Thank you for acknowledging my practical experience or what ever you meant by that since we were speaking in theory.
i still dont understand this line of thinking. if the purpose of these calculations is to determine the size of cables required to safely do the job, how can you possibly ignore what the numbers are in fact, and instead use nominal standards? what i'm getting as a reader of this thread is the 230v/400v are national standards, but not actually used in most states, and likely a fiction in the states where they are used. surely noone is basing safety related calculations on fictional numbers?
thanks, chaps.
these are just two irrelevant asides...
the corner substation next to my house was refitted about 4 years ago. the guys were here every day for 3 weeks or so, and told me the hardware had not been changed for something like 50 years. i did see the cables which fed the substation under the street, and boy were they huge! i was amazed by how much manpower, time and hardware can be absorbed by a substation measuring about 10m x 8m (with 2 levels in side). their final push was a 36 hour marathon non stop. i was away at the time, but they told me when i got back at the tail end of it, that someone had made a noise complaint to the police in the middle of the night! you have to wonder if some people have a brain at all...
last year, a truck hooked the power cables at the family home of my former partner. pulled the barge board off the house etc. she went outside to find the cables on the ground, and the truck driver, who decamped quite quickly told her that it wasnt a problem, as they couldnt be live if they were on the ground!! she called me and of course i said dont go anywhere near them, and to call the police immediately.
apparently, live power cables on the ground wasnt a good enough reason for the police to attend! so they sat there for an hour till the power guys arrived. unbelievable on all counts.
If you want the power people to turn up really fast, don't just tell them there are live wires on the ground. Tell them you have just had a tingle, then you discovered the live wires.
Roger
The real risk is fact that many novices rate a cable a the ideal current and then enclose it and fuse it at the maximum. Cable needs to de-rated depending on how it installed and for length. In short run , less than 50 meters it seldom causes a problem. But 220 metre run to the workshop should be calculated for size and likely load.
