How does that statement share the knowledge?
Is there some sort of generator exfrogger can buy to supply 3 phase, instead of spending $50,000-00 of his hard earned readies ?
Yes Ken, that's SWER. Signle Wire, Earth Return. Only one wire in. I think that's what Rob meant by "pole transformer" but I added the second paragraph when I realised I couldn't be sure what Rob meant. I hope Rob chips in again.
Roger
What you have then is a composite of the pdf.
If you removed the secondary of the the first transformer and removed the primary of the second transformer and grafted the remaining windings into a second transformer - then that is what you have.
Ie you have a 22kv to 480v ct transformer.
G'day,
well, now I have some idea about 3 phase, before I had none. Is there some sort of generator exfrogger can buy to supply 3 phase, instead of spending $50,000-00 of his hard earned readies ?
bloody academics...
Roger,
A minor correction. 480 volts does not exist as a Australian standard supply voltage.
The nominal phase to neutral voltage is 240v and nominal phase to phase voltage is 415v.
This is because of the sinusoidal angle relationship of the three phases, being 120 degrees separated.
Thus two phases provide 415v and not (2x240) which is the numeric, non vector addition, a misnoma.
For the record:
three phase voltage = (single phase voltage x root3)
cheers
Rob
Australian Standard Voltages are as follows:
Single Phase is 230 volts
Three Phase is 400 volts
This was introduced a few years ago to align Australia with the European Standards
Not strictly true Col. It was hoped for but never really happened.
Attached is the current standards, and of course I stated Victorian standard since both Roger and I are in Vic.:wink2:
I did quote the Australian standard not the Office of the Regulator General, Jan 2002. (Victoria).
I'm in Tasmania and we are aligned to the Australia Standard.
Col, put an accurate voltmeter on your supply. I bet my left one it's closer to 240v than 230v.
Supply companies will always avoid a "brown out" and hover on the high side.
Having a higher supply voltage increases the power cost for the consumer because a higher voltage ends up having higher Kw/hour readings on the meter!
There is no motivation sit dead on the low end of the "standard" voltage. Especially when there is standard range.
roger, isnt that what is depicted in the PDF in rob's post? on the one hand you are saying you dont have that, but in the quoted words you seem to be saying you do?
I spoke to many rural electricians and 480 volt was often referred to as Double Single phase. It must have had the phases 180 degrees to obtain the phase to phase 480V. It was fairly common and had fewer problems with volt drop under load.
I dont understand how it was obtained, as power is generated in Victoria (and Australia) and distributed as three phase, with 120 degree vectors or phase shift, at various voltages. So I don't understand how 180 degree vector angle is obtained from the distrubtion network?? Logically I dont think it can be, a single leg of the three phase must have been used and reduced to 480 volt? Other phases would have been sent to different consumers for load balancing.
Rob would you put your right one up that your right or Col is?
Because if you do you owe him your right knacker. Col is correct, AS/NZ Standards now state 230V and 400V and all calculations are now made with those figures.
You can still keep your left one because if he put a meter he would more than likely be closer to 240V than 230V.
