- Joined
- Sep 6, 2003
- Messages
- 492
<snip>
what do you think should I do?
Buy a new head from ClubDjet?
cheers! Peter
<snip>
Be nice to get you and Frans together!In my mind the percentage gain in performance from 12.07 to 12.4 would be quite small, maybe 2%. I have no testing to prove this, only that compression ratio gain has diminishing returns at that level, although also dependant on the fuel used.
What thickness head gasket do you use? Some years ago I had a custom one made for a BMW E30 M3. The standard gasket was 72 thou compressed, the new one started at 40thou, although of course this can introduce valve clearance problems with the size cam you are likely to be using, but no different to removing material from the head face. A lot of work, but the block and liners could be machined to allow the pistons to protrude into the head gasket thickness area to gain some more compression.
Murphy is alive and well but certainly not looking at your big ends!! Those conrod bearings are quite a sight! You must use good oil Frans.Now that is so typical Murphy. The mains arrived about an hour after I fitted the sump!!!
Angelo, I am sure that it was a factor. The oil got so hot lately that the temp was somewhere over 150 because that is how far the gauge goes. In one of the videos, you can see that on the last lap the pressure dropped to about 10psi or there about. I have never had starvation due to aeration. That normally destroys the engine instantly. I have in the meantime done quite a bit on the cooling side with great success.
But as SZ said mentioned, I had some luck on my side by stripping the engine in time.
Regards, Frans.
Oil temp in Celsius I presume? That's so interesting, for me at least. Mine has run 60 psi at 3000 rpm at normal water temperatures forever. If it gets over 90 degrees (water not oil) it drops a wee bit below 60. Never idles below 22-25 psi regardless of temperature. 360,000 km and one set of new bearings in 1988.Sorry Ray, I never saw the question. It is 55 psi up to 145 degrees, 60 psi when it drops down to 130 degrees.
I have just fitted the old engine with its new head and I will start it tomorrow. So holding thumbs that it is back to normal reliability like in the past. The old head had one valve guide that was fitted at a different angle as the others, it was lying visibly further out towards the outside, but they are all in line with this head . That is a plus for me although I never had issues with the other skew valve.
I won't drive it yet as I will need a new Warrant of Fitness and that I can only get next week.
Regards, Frans.
Sounds good Frans! I've often wondered what my oil temperature is. After a hot run here, the coolant is around 90 degrees and the oil hotter than usual - must be hotter because there's a threshold of some sort where idle speed oil pressure fluctuates rapidly in the 20-25 psi range rather than being fairly steady at its usual 24-26 psi. I use Penrite 20-60 mineral oil (the one with "full zinc"). Hardly racing conditions of course!And the best to you guys as well John.
Yes, that is Celsius. I had the same oil pressure as you on the Matra down to the South Island and back, but that was with an oil temp of 100 -110 degrees all the way running around 4k rpm. When the race car's temp exceeded the gauge's scale of 150 + the oil press dropped drastically. It could have gone to 180 deg who knows. That is surely the reason for the condition of those big-ends. I have recently changed to the thickest full Synthetic oil, Penrite. It was running on Mineral oil for the last 9 of 12 years.
I have made the scoop under the body to catch air and force it through the oil cooler that helped the temp to stay around 140 -145 deg. That maintained the oil press very well. I have now added 2 x 12V server fans, those that sound like a helicopter taking off, in the ducting and incorporated their switching into the onboard PLC so that they stay off with normal driving and activate as soon as we start racing, all automatically. That is an inverted/opposite operation of the alternator that runs during normal driving and turns off when racing. Because I use a small 18 Ah battery I did a test with the battery and ran the fans for about 20 minutes with no substantial voltage drop. This is yet to be tested.
I started the new-head engine on the 31st and it sounded as good and crisp as always. Johan and I decided to go to a Playday first before we enter a full race day. Our racing season is buggered in any case because of the lockdown and the first race is in Taupo, 800 km return. I wouldn't like to test the engine so far away.
I will let you know how it went at the test.
Regards, Frans.
