Can you elaborate a bit on the causality of the issues? What, for instance, is the contra-indication story for synchromesh?Beware of shockproof, this term is usually reserved for Dog boxes and plate LSD and is kiss of death for synchro boxes. Always remember competition boxes are usually non synchro. We are using road boxes for racing. Friction modifiers and cushioning properties are not for synchro use.
You have been warned.........
LightWeight is a unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions). It has excellent low-temperature flow which allows easier shifting when cold. May be used to obtain maximum power transfer in racing differentials which do not see high temperatures. Similar to a 75W140 gear oil, but with the lower internal friction of an SAE 30 motor oil.
This taken from Redline's website.
Do not use in Renault transaxles
The problem is that there are additives in the oil and sometimes tiny particles which are there to cushion the shock on the Dogs as they Bang into engagement. The gears are all constant mesh and assuming there is no excessive clearance or wear issues, there is little shock load on the actual gear teeth. Some of the oils are black as they contain Graphite which coats onto the running surfaces or other additives which do the same thing. A synchro box works on friction , so you are just putting yourself at a disadvantage using the wrong product.Can you elaborate a bit on the causality of the issues? What, for instance, is the contra-indication story for synchromesh?
I admit upfront the oil is not meant for synchro gearboxes.Beware of shockproof, this term is usually reserved for Dog boxes and plate LSD and is kiss of death for synchro boxes. Always remember competition boxes are usually non synchro. We are using road boxes for racing. Friction modifiers and cushioning properties are not for synchro use.
Always remembering that Multigrades were a few years away when the 300 series Trans were fitted. Makers info can get `Frozen in time' as it were.Penrite recommend the following oils:
300 series transaxles: Pror Gear 75W-85 https://penriteoil.com.au/products/pro-gear-75w-85-full-syn
NG series transaxles: Trans Gear 75W-90 https://penriteoil.com.au/products/trans-gear-75w-90-semi-syn
Castrol recommend the following oils:
300 series transaxles: Castrol Manual VMX80
NG series transaxles: there is no recommendation
Its interesting what the above oil companies recommend and what Steve is saying about the differences in synchros between Renault's 300 series and NG series transaxles.
Well I've taken out the Lucas 80W-140 Heavy Duty Gear Oil (ie treacle) and now filled with the Lucas Synthetic 75W-140 gear oil. Immediately you could see (by poring it out) that it was much thinner and a far cry from the "treacle".I admit upfront the oil is not meant for synchro gearboxes.
I knew some racers many years ago that were using it in their synchro boxes successfully, with a most amazing drop in the race temperature in these boxes. I tried it around 20 years ago, with similar results regarding temperature, and have it in 4 synchro and 1 dogbox, and a diff in my own vehicles, 3 of these being Renault transaxles. I have had no problems, and it even improved the synchros so much in a friends Alpine GTA Turbo box that he was about to rebuild, that it never did get done. That was about 14 years ago. As you have said, Redline recommend other products in their lineup for our Renault transaxles.
In the past I have seen many cases of 80W90 oil being used in Fuegos, which seemed to destroy synchros, but the boxes lasted well with Castrol VMX80, so I don't think it was a general failing in the build materials of the box. There must be more than a slight increase in viscosity causing this. Perhaps it was a GL5 oil that at the time at least, did not get along with yellow metals, being the brass type synchros used.
I followed Alan's experience with the Redline shockproof and have had it in my 314 gearbox (4CV) and 330 gearbox (R8) for some years now. (Mr Dauphproto, re 2-year changes, I'm guilty!) I've had no issues and good changes. I think with modest km/a (1,000 - 5,000 averages) and a mild climate without seriously cold temperatures (condensation) I can run more than 2 years between changes but I'm not arguing for one moment for UK conditions. I'll change the R8 now though as it has done more like 20,000 km I think and it must be more like 5-7 years since I replaced the selector rod seal!!!Well I've taken out the Lucas 80W-140 Heavy Duty Gear Oil (ie treacle) and now filled with the Lucas Synthetic 75W-140 gear oil. Immediately you could see (by poring it out) that it was much thinner and a far cry from the "treacle".
I took the R8 out for a drive on Sunday (to MotorClassica in Melb CBD - 10kms) and eased the gears in whilst allowing for the oils and motor/gbox to get up normal operating temp.
Although all shifting of gears was easier, the 3-4 gear up change still had some grating (admittedly reduced).
I'm with Aln that although not meant for syncro gearboxes, the Redline shockproof in my opinion has performed much better with smoother changes in all gears and no grinding at all, especially in the 3-4 up change - with the only caveat on the shockproof that it must be properly warmed up before using it in anger.
Considering the low kms I do (albeit working slightly harder not being an every day at all but doing the occasional track/regularity/sprint event), I am seriously thinking about going back to the shockproof - if you can get 14 years of trouble free changing, then the syncros will will probably outlast me.
I don't fully understand the science behind it, but if it works, I believe leave it alone.
My thoughts and (limited) experience only
I'm not up with the lubrication theory and practice, just to start......I admit upfront the oil is not meant for synchro gearboxes.
I would give the new oil you have used a bit longer to prove itself, maybe a few hundred Klms. I know in the past with 2 Fuegos, that changing the oil from 80W90 to the 80W the synchros would improve over a month or so of regular use. I have no explanation of this as I would have thought any of the old oil film left on the synchro or cone would be gone in minutes of use.I took the R8 out for a drive on Sunday (to MotorClassica in Melb CBD - 10kms) and eased the gears in whilst allowing for the oils and motor/gbox to get up normal operating temp.
Thanks for that. The Redline oil certainly doesn't smell like Castrol Hypoy 90 I agree!I think it would be worth an e-mail to Redline's customer service to ask about Suitability, There may be a Synchro version of the oil available which would give you all the benefits and none of the drawbacks.
I remember helping a mate strip a Tremec 5 speed and wondering why the inside of the box had been painted Yellow, then realising that this was the Sulphur that had spun out of the oil and had coated the entire insides of the box. This was an Ex TVR Tuscan Racer which had been retrofitted with a big Ford V8. This had been using old fashioned High Sulphur Race Gear Oil.
I have noticed that most of the new multigrade oils do not have the classic smell, it is still there, but much less than the EP of my youth.
Another thing worth remembering is that we are all trying our best to get the maximum service life out of our vehicles (Me included)
My Mate when he was challenging for the Scottish Tarmac Championship (and winning) was replacing the Dog rings in His Hewland box 2-3 times in the season, Which reduced to annually with the advent of Powered sequential shift (with an ECU on the box to control the shift including a servo motor for blipping the throttle on the Downshift) meaning the machine was better at changing gear than a Human
Some of the guys in the Scottish Classics championship are Changing Ford Baulk Rings after 2-3 races, the quality of the re-manufactured parts is that poor.............................
I guess that inside the synchro hub it takes quite a while for the oil to exchange. Not that I'd have predicted this but it does make sense. Maybe it needs practically all of something that is in the 80W90 to be removed? Interesting. I'm very happy with the Redline oil and am pretty sensitive to how the gearbox feels - I guess that if there were a problem, some 20,000 km would have shown it up!I would give the new oil you have used a bit longer to prove itself, maybe a few hundred Klms. I know in the past with 2 Fuegos, that changing the oil from 80W90 to the 80W the synchros would improve over a month or so of regular use. I have no explanation of this as I would have thought any of the old oil film left on the synchro or cone would be gone in minutes of use.
