Hello Frans.Hi all,
I have uploaded another You Tube clip for you to see.
this is from Saturday afternoon and as I had only 4 laps practicing you might note that I tried a few different gears and different lines because I didn't know the track yet.(good excuse!) I have edited the video to show only the 1st 4-5 laps. Were the video ends is how the race continued and became boring. That is how we finished. The Torana that I took down the straight is a 6 cylinder one.
I have a lot of respect for the Fiat 128 that overtook me. It is very quick and the owner is a good driver as well, he did a lot of Go-Kart racing. The engine started life as 1500 SOHC out of a X19 and was developed from there.
http://www.youtube.com/watch?v=B5oaaIOgkus
Frans.
I am racing with a 1134 (1148 in volume) here in Sweden, and it is interesting to listen what you have done. I have a problem with the brakes, but first I tell you a little about my car.
The rules here in Sweden are a little different to what you have. We are, for example, not allowed to widen the wheel track, and therefore we can't lower the car by cutting off the springs. I have instead modified the beam over the gearbox, so the gearbox is 4 cm higher up in the beam. And we are not allowed to use 13 inch alu-wheels, if they not are in the papers from F.I.A. in Paris (the paper is called "Appendix K") for R8 1134.
I have polished crankshaft and connecting rods in the engine (I enclose a picture).
I have a rev limiter adjust to 8500 rpm. When I listen to your car it sounds a little lower. I enclose a short clip from a test we have done. http://www.youtube.com/watch?v=HyhTqqD0pmw
Now to my problem with the brakes:
I have changed the master cylinder to a new one with 19 mm diameter, no servo, new brake hoses and overhauld calipers. I have no brake reducer for the rear brakes, the one which normaly is mounted on the rear beam.
The calipers are filled with brake fluid before they are put together, and very carefully bleeded after mounted, so no air is left. But still it feels like air in the system, I can press the pedal down to the floor, if I press hard!
After that I disconnect the pipes from the master cylinder and plugged the cylinder. Now the pedal is hard!
Then I mounted back the pipes, and disconnect the brake hoses and plugged them. The pedal is still hard!
After that I connect the calipers again, one by one, and tested after each one, and the pedal will be softer and softer, and when the last one is back the system is as from the beginning, I can press the pedal down to the floor. Any ideas?
Thankful for help.
Gösta
